Trick to get the ABS light off
I found this web site that shows a way to get the ABS light off and keep it off. I hope it helps someone else out. I tried it and it works, I used a piece of plastic that was in a wedge shape and it worked like a charm. Good luck
Volvo S70-V70 Abs Module repair | Car Instructions
Take the module off, contact BBA- Reman, and have them rebuild it. Costs about $60, and they guarantee it for life. Yeah, the shim- it fix works for a little while, but eventually, the connections wear further and the problem will come back again.
Not exactly. Sometimes wires break loose at the solder joint to board. The proper fix is to resolder them, but the wedgie works (sometimes) by putting pressure on the connector and pushing the wire into solid contact with the board. I guess the vibrations might cause intermitent contact/loss of contact but the real culprit is just a crappy soldering job.
