Water on Drivers Side Floorboard
Old Oct 26, 2022 | 07:17 PM
rickster9's Avatar
Default Water on Drivers Side Floorboard
I checked the door drains, sunroof and the 2 openings on the cowl by the fusebox. Nothing so far. If anyone has any ideas, please advise.
Also looking for a good replacement antenna that lets me keep the black mount that goes on the outside.
Thanks
Old Oct 27, 2022 | 06:58 AM
Dingus1's Avatar
Does it smell like coolant? ie: Heater Core leak
Does it only happen when it rains?
Old Oct 27, 2022 | 08:42 AM
Psaboic's Avatar
That is what I was thinking too.....heater core. Outside of that I would check the windshield seal. You could dry it out, pour water down the sunroof drains and see if it leaks....
Old Oct 27, 2022 | 08:29 PM
rickster9's Avatar
No, not the heater core, it's when it rains.....
Also getting heavy vibration on highway exit turns going about 40 mph (recently changed tires). Tie rod ends?
Old Oct 27, 2022 | 08:39 PM
Originally Posted by rickster9
Also getting heavy vibration Tie rod ends?
No---
Old Oct 28, 2022 | 08:12 AM
maggs's Avatar
Could it be coming from the AC evaporator in the bottom/center of the dashboard?
Old Oct 28, 2022 | 08:32 AM
Psaboic's Avatar
First and foremost, check the lug bolts to make sure they are tight. Then, if still vibrating, swap the tires front to rear. If that does not do anything positive, then start checking the fron and rear suspension components
Old Oct 29, 2022 | 10:44 AM
rickster9's Avatar
Thank you for the vibration tips. As far as the wet floorboard I guess the only thing I have not checked is the windshield seal. Should I be sealing up top where the windshield meets the roof or down the side?
Old Oct 30, 2022 | 09:38 AM
Psaboic's Avatar
Others may chime in as I am no expert, but what I would do if you suspect the windshield seal is this. Pour water down each side of the windshield, starting at the bottom, and check for water leaking. If it is good on the bottom move on to each side one at a time, checking for water each time. Finish at the top, that should tell you if it is the windshield leaking and where. Is the leak a static leak i,e if the car is sitting overnight and it rains do you find water, or is it only if the car is being driven?
Old Nov 13, 2022 | 10:27 PM
rickster9's Avatar
Should I be sealing up top where the windshield meets the roof or down the side of the windshield, where that water barrier thingy is?
Old Dec 3, 2022 | 10:28 AM
rickster9's Avatar
I found the leak. It's in an unexpected area. It's under the fuse box under the hood on the driver's side. That's a project for another weekend. Windshield snow cover in the meantime to keep the rain out. Thanks all.
Old Dec 4, 2022 | 09:49 AM
Psaboic's Avatar
Glad you found it. Thanks for letting us all know in case others encounter the same issue
Old Dec 6, 2022 | 05:40 AM
firebirdparts's Avatar
Yes. There is a huge hole there clean through the cowl, and I get leaves down in there stopping up everything very often. I am really careful to keep that stuff cleaned out for that reason. It really doesn't appear that anybody had a serious idea of how to keep water from going down through that huge hole.
Mtate32
Aug 9, 2020 03:10 PM
In California
2001-2013 model year V70
Jun 16, 2019 10:43 AM
vadim k
Nov 27, 2010 09:11 PM
b26440510
Nov 10, 2009 07:52 AM
JimBee
Aug 10, 2009 06:38 PM
