What year cylinder heads will fit a 99 2.4 non-turbo?
Old Sep 13, 2009 | 09:24 AM
texan_176's Avatar
Default What year cylinder heads will fit a 99 2.4 non-turbo?
My friend who ran the car without coolant had it at a mechanic since I have never disganosed or done a cylinder head repair. If the cost is going to be over 1 grand they will probably dump the car and I can get it for nothing.
I might just drop in a used engine but if I were to replace the head what years are identical replacements?
For some reason I can't find any engines for the S70s in self service yards where it's very cheap to buy parts.
Will the 850's heads work on them as well?
Old Sep 13, 2009 | 09:37 AM
No the 850 head will not work.
The 99 and up cars have VVT (Variable Valve timing) which they are different heads.
Old Sep 13, 2009 | 09:37 PM
Carrots's Avatar
You need a non- turbo 99 or 00 S/V70 head. Period. The turbo heads have different valves, and the 98 and down heads don't have VVT.
Old Sep 13, 2009 | 10:07 PM
texan_176's Avatar
Thanks for the replies.
I am still considering just dropping in a sub 100K mile engine that I replace all of the seals on, put on a new water pump, T belt, idler pullies, tensioner, plugs, etc...
Cheapest one near Houston I found is $750 with 80K miles.
I had found one for $300 earlier but it seems to have had the T belt snap so it's not worth repairing and the headaches/bloody knuckes.
Carrots
Feb 14, 2017 10:18 AM
connect2u93
Oct 22, 2013 05:22 PM
1steven
Aug 24, 2009 11:26 PM
burnferris
Feb 8, 2009 04:43 PM
GLTLOVER
Mar 28, 2007 01:10 AM
