Squiky brakes, need help
Old Sep 12, 2009 | 09:57 PM
Ruskya Mafia's Avatar
Cool Squiky brakes, need help
Helo I have squiky brakes, everytime I press the brake padel it makes a squiky sound. I had my brakes changed like 2 month ago, and I drive a 98 s70. Do u guys have any ideas on how to stop this, exept for changing the brakes because I have new ones
Old Sep 12, 2009 | 10:37 PM
gilber33's Avatar
There's a liquid that you get, almost like a glue, that go on the back of the pads. Brakes squeeking aren't from the brakes on the rotors when you stop, they're from the the brake pads vibrating, this stuff subdues/stops the vibration.
Old Sep 13, 2009 | 01:21 AM
blackbrick's Avatar
It is silicone grease (autozone, walmart) that you put on the back of the pads and back of the shims. If you could buy cut shims it would help too.
Old Sep 13, 2009 | 09:15 AM
LOL! Welcome to the European Auto Owners Club!!! What you have is a harmonic hum, like rubbing your finger around a wine glass rim. When the brake pads were installed someone should have installed the very thin pad shims and applied a type of grease that stops that. It is VERY COMMON. There is also a type of grease that can be applied to the back of the pad to stop it but I would use the shims if possible, it's more permanant.
Old Sep 13, 2009 | 12:17 PM
wat is SHIMS? i never heard of such a thing before?
Old Sep 13, 2009 | 03:16 PM
they are very thin pieces of metal, a little thicker than aluminum foil. Usually the size and shape of the brake pads.
Old Sep 13, 2009 | 03:28 PM
blackbrick's Avatar
these are cut shims
Old Sep 13, 2009 | 03:30 PM
blackbrick's Avatar
check this link out to see DIY http://volvospeed.com/850rbrake1.php
Old Sep 14, 2009 | 01:47 PM
ok thx guys...
Kilika
Sep 18, 2021 03:16 PM
elmo_allen
Apr 16, 2010 08:46 PM
chef
May 19, 2009 05:57 AM
tozee
Mar 10, 2008 07:27 PM
SDVOLVO
Jan 29, 2006 08:42 PM
