00 t6 "brake" problem
Old Jan 17, 2009 | 08:29 PM
neill1223's Avatar
Default 00 t6 "brake" problem
started car today and had msg appear saying brake failure urgent svc along with check engine light, abs, tc and one other one.
hooked up obd II computer and nothing to do with brakes in there so cleared light and also pulled abs fuse, it cleared lights.
back in the car later on it happened again this time the abs and tc light still on and msgs saying abs service, stc service and also power steering service required.
what would cause this?
i was thinking ice on a sensor?
any help much appreciated.
thanks
Old Jan 17, 2009 | 08:31 PM
Default RE: 00 t6 "brake" problem
I will bet the ABS module is bad.
Old Jan 18, 2009 | 10:09 PM
neill1223's Avatar
thanks tech, that i think is what i was hoping it wasnt.
what are these things like to get to?
i heard that they are not cheap to replace.
Old Jan 18, 2009 | 10:17 PM
Check this site here he will rebuild for about $100.00 it also shows you how to take it out.
http://home.earthlink.net/~vicrocha/...vo_V70_ABS.htm
Or if you are handy see this post.
https://volvoforums.com/m_58856/tm.htm
s70_t5_1999
Jan 22, 2010 11:53 PM
MaZoN
Aug 5, 2008 06:52 PM
thullz
Nov 7, 2006 09:25 AM
mywifescar
Jan 13, 2006 12:59 PM
