02 S80 HIGH BEAMS WONT WORK
Old Jun 26, 2008 | 10:03 AM
benithegreat's Avatar
Default 02 S80 HIGH BEAMS WONT WORK
I recently changed the headlight myself because I wasn't going to pay the dealer $500 to do it. I got everything right but now the high beams on that headlight wont work and all the wiring is good. HELP
Old Jun 26, 2008 | 05:24 PM
mncx's Avatar
Default RE: 02 S80 HIGH BEAMS WONT WORK
Is headlight switch on the last or thirdposition.. if it at "0" high beam will not stay on... but u can still flash your high beam... Check your fuse if u are in correct position. hope that helps
PS once in a blue moon the connector of the high beam bulb may burnt up.. I hope that didn't happen to you.
Old Jun 27, 2008 | 09:06 AM
The thing is the other light that was one, the high beams work for it but this light that I changed, the high beams don't work and all the plugs are in and the fuses are fine
Old Jun 27, 2008 | 11:56 AM
jlewisinsyr's Avatar
Simple as it sounds, but did you check the bulb to just make sure it wasn't blown? Swap the bulb with the other side?
Old Jun 27, 2008 | 11:59 AM
I put in brand new bulbs when I bought the light I'm going to have to check the wiring again. I need a repair manual does anyone know where i can get one cheap?
Old Jun 27, 2008 | 02:49 PM
Just because they are brand new doesn't mean they're not broken...before you go crazy, I'd at least try and make sure it wasn't the bulb.
98isb360
Oct 13, 2021 08:47 AM
bkhan145
Mar 16, 2019 02:22 PM
bcolins
2001-2013 model year V70
Nov 22, 2013 09:49 AM
gsmith39
Mar 29, 2009 10:02 PM
hkburke
Jan 18, 2008 05:03 PM
