04 S80 T6 Reduced Engine Performance warning
Old Aug 18, 2012 | 06:45 PM
sdl92's Avatar
Default 04 S80 T6 Reduced Engine Performance warning
I have an 04 S80 T6 with 232K. I recently fixed a hard starting problem by replacing the fuel filter, fuel pressure regulator, and finally the crank position sensor. A few thousand miles later a Reduced Engine Performance warning light came on. The car lost power, slowed to about 10 mph, pushing the gas pedal to the floor did nothing. I coasted to a stop, the engine would only rev to about 1500 rpm with the pedal to the floor. I shut the engine of, waited a few minutes, re-started the car, and it ran great for a few days, then the problem occured again. Same fix worked. This began happening on a daily basis. At the suggestion of a non-Volvo mechanic, I un-plugged the MAF sensor. The car ran great for a few days, then the Reduced Engine Performance light came on and back to the same old problems. I am a long way from a Volvo dealer, or anyone willing to work on Volvo's. The non-Volvo mechanic says his code reader says there are problems with the throttle position sensor. I haven't been able to find this part online. Any ideas as to how to solove this problem would be greatly appreciated. Thanks
PapaPhive
Jun 19, 2018 07:03 PM
volvoplett
May 15, 2013 09:34 AM
AronS40
Jan 17, 2013 10:11 AM
acentre
Aug 2, 2011 05:40 PM
