1999 S80 2.9 problems
Old Aug 15, 2007 | 12:02 PM
brokeDownS80's Avatar
Default 1999 S80 2.9 problems
i have a 1999 s80 2.9 with the following issues:
- rough idle / choking / loss of power
- engine requires urgent service (something like that) andexhaustcodes coming up
- black smoke
- rotten egg smell
- cylinder #5 not working
- strong gas smell from under hood,looks like maybeleaking gas, i guess due to cylinder #5 not working
If the car hasn't ran for a while then it runs good for a bit and all of a sudden it starts running rough and I get all of the above symptoms. Any help would be greatly appreciated.
Thanks guys.
Old Aug 16, 2007 | 10:16 PM
master_pre's Avatar
Default RE: 1999 S80 2.9 problems
The rough idle is probably a software issue. Have you had the software update?
The other problems sound like mechanical issues. You could always take the car to the mechanics and get a free diagnostic on what the problem is. Once you know what's wrong you can decide whether to fix it yourself or let them do the work ($$$).
Old Aug 17, 2007 | 04:31 PM
Sounds like you might either have a bad coil pack or a bad injector.
But you could also have more problems.
You need to have the codes pulled and see where they lead you.
Old Aug 18, 2007 | 10:34 PM
kyvahe's Avatar
I had the rough idle, i.e. it would bouce from 1k-500 range and then repeat... the dealer did a software update and it doesn't do it anymore.
Old Aug 18, 2007 | 10:39 PM
kyvahe's Avatar
all of the other problems are probably being caused by a single other problem... happened when i had my old turbo car getting too much gas vs air.
Old Aug 31, 2007 | 06:26 PM
go2sharks's Avatar
wow, what the.
The guy said cyclinder #5 not working. Yes, that's the problem.
The question is, how do youknow #5 if not working?
If you guess, then that's a good guess. Fix it.
If you someone told you, then maybe that someone also told you what the problem is. Fix it.
Check this out... Oh, I got a bad knee.. I having use it for a while. what could be a problem? Any help will be appreciated.
The guy said bad knee.. and people are suggesting it's his head.
Sorry, Tech.. You're on the money!
darkostoj
Aug 1, 2018 08:27 AM
thy_wolven_lord
Jun 5, 2011 10:24 PM
rezology
Jun 13, 2010 10:42 PM
raygnlz
Jan 16, 2010 12:00 AM
7antera
Jun 2, 2008 08:00 AM
