1999 S80 Window does not open
Old Mar 1, 2008 | 02:05 AM
vy22's Avatar
Default 1999 S80 Window does not open
My 1999 S80 T6 front right window does not open. It goes down about 1 inch. That's all. It can go back. What was wrong? I like to open the door panel and take a closer look. How to open it? I found a few plastic 'pins'. Do I need special tools to remove them? Thanks.
Old Mar 1, 2008 | 06:33 AM
Default RE: 1999 S80 Window does not open
The center of the pin will push in a little then click. Then the pin will slide out.
Then where you grab to close there is a cover remove the cover and the 2 screws and the panel should slide off.
Old Mar 1, 2008 | 11:31 PM
vy22's Avatar
Hello tech
I'll try that. Thanks a lot.
andrei3333
Dec 1, 2009 06:22 AM
Deepesh
Jul 11, 2009 09:38 PM
guptash
Nov 25, 2008 09:39 PM
