2000 S80 T6 DTC P0014 & P1513
RE: 2000 S80 T6 DTC P0014 & P1513
See: http://volvospeed.com/vs_forum/index...howtopic=77556to find about p0014
Fixed! First i broke down and purchased the pricey front heated 6 wire O2 sensor and that fixed P0030, and the car drives better than ever now. Then i attempted to clean the camshaft position solenoid for the P0014 code, it helped but it still threw the code every six times i drove it instead of every three, there was oil varvish that would not come off the old solenoid valve even with carb cleaner or maybe the electrical portion was bad. So i went ahead and spent more cash at the dealer and bought a new solenoid and gasket, put that on and now i have driven the car at least 10 times with no codes. Glad i was able to fix it myself since the pars were expensive. i am finding that these volvos are easier to fix then american cars, if you open your mind and do a little research before you start, no big deal
additional info,
Theengine shudders mildly, intermittent (every trip) at around 55-65 Mph, alsothe enginehas an intermittent (1 in 12 trips) rough idle for a second and returns to normal. Gas mileage has gotten worse but not too bad. When the light first came on two months ago,was when I noticed the intermittent (1 in 12 trips)rough idle. Just before the DTC codes came on I had been running the motor at wideopen throttle 33% of the time for 2 months previously.
