2000 S80 T6 engine oil leak
Old Aug 9, 2010 | 05:26 AM
ToowoombaT6's Avatar
Default 2000 S80 T6 engine oil leak
I am new to this forum and also new to Volvo's. I have just purchased a S80 T6 and absolutely love it. One glitch is I have an oil leak, it seems to be from the upper rear of the engine at the transmission end of the motor. I have checked around the valve cover and it is dry but there is oil over the top of the gearbox, down the rear of the block and on the exhaust manifold above one of the turbos. I found a couple of vacuum hoses that had collapsed from age and heat which I have replaced.Just after advice before I start pulling off heat sheilds to try and see whats going on...many thanks
sparro
Oct 11, 2011 01:27 AM
ROBLU540
Feb 20, 2009 07:59 PM
1999S80T6
Dec 16, 2008 04:54 AM
siever76
Dec 1, 2007 07:39 AM
