2000 s80 t6 oil leak
Old Nov 21, 2007 | 01:28 AM
siever76's Avatar
Default 2000 s80 t6 oil leak
Got an oil leak coming from in front of the oil pan. Just took it to the shop a couple of weeks and they thought it was coming from around the oil filter. They changed the oil etc. Still got that same oil leak. Going to check it out this week myself is there anything I should look for? Any suggestions would be appreciated.
Old Nov 21, 2007 | 06:37 AM
Default RE: 2000 s80 t6 oil leak
Look for front cam seals leaking or vent box.
Old Nov 21, 2007 | 03:40 PM
natedog74's Avatar
If it is running down from the front side of the engine, I would say the vent box seals or the dipstick seal-ring.
The dipstick is not to hard to do but the vent box is hard to get to.
Depending on how diy you are, you may want to have a shop do the vent box.
Old Nov 21, 2007 | 04:13 PM
siever76's Avatar
Thanks for the info. Can I see the vent box without having to remove anything.
Old Nov 28, 2007 | 02:21 PM
siever76's Avatar
Did not get a chance to look into over the holidays, but did take it back to the volvo shop today. Called me back later today and they want to keep it until tomorrow. He believes the oil filter housing might have a crack in it is this possible.
Old Nov 29, 2007 | 09:06 PM
siever76's Avatar
It is the vent box. What other parts should be repalced while replacing the vent box.
Old Dec 1, 2007 | 07:39 AM
I would replace the vent box, Hoses, make sure you have good clamps. The screw clamps do work all that well on the hose that goes to the block. Make sure you buy a new intake gasket as well.
EisenhardtS80
Dec 20, 2013 11:04 PM
sparro
Oct 11, 2011 01:27 AM
castlehotrod
Jan 24, 2011 01:50 PM
ToowoombaT6
Aug 9, 2010 05:26 AM
ROBLU540
Feb 20, 2009 07:59 PM
