2000 s80 wont crank
Old Nov 2, 2015 | 05:52 PM
tjsilva's Avatar
Default 2000 s80 won't start
So Saturday I pulled the Volvo forward in the driveway so my brother in law could pull in to the driveway, no problems. Sunday afternoon I go to start it and nothing, sounded like the starter was spinning but not cranking engine. I figured the the bendix was stuck not sure if that is what its called. today I replaced the starter and I have the same. Starter fuse ignition fuse are ok. Any advice on what I need to check next? Any and all help greatly appreciated, engine is 2.9 non turbo.
Old Nov 2, 2015 | 11:31 PM
do you hear the click of the solenoid and no cranking sound or can you hear the starter motor whirr without turning the engine?
Old Nov 3, 2015 | 09:48 AM
tjsilva's Avatar
Sounded like I could hear the whirr without turning engine. Last night I swapped the starter relay with the ecu relay, now the engine cranks but wont start. I am thinking that is because the bad relay is now in the ecu spot. I am picking up a relay today to swap it out with and let you know if it works.
Old Nov 3, 2015 | 04:20 PM
tjsilva's Avatar
Ok the car is cranking now but wont start, maybe it was cranking before not sure. Any idea where i should start? no messages on the display.
Old Nov 3, 2015 | 10:04 PM
next is to test for spark.
Old Nov 6, 2015 | 07:02 AM
tjsilva's Avatar
Not sure if the relay was the problem but I got her running again and so far no problems. Thanks for all that made suggestions.
jquiding
Feb 17, 2014 04:16 PM
Lavid2002
May 26, 2011 06:00 AM
Lavid2002
Mar 1, 2011 06:20 PM
datderboy216
May 22, 2010 06:38 PM
rpsail7cs
Sep 25, 2009 09:12 AM
