2000 T6 not starting
Old Nov 21, 2010 | 09:32 PM
nkdmonkey's Avatar
Default 2000 T6 not starting
I have a 2000 S80 T6 that blows the "engine control unit injectors" fuse every time I try to start it. It started a week ago and when I changed the fuse it started fine for a few times, then it started blowing the fuse more often and now it blows it every time. When I could get it started it seemed to run like normal. Anybody have any ideas on what the problem might be?
Thanks,
KRIS
Old Nov 22, 2010 | 02:04 PM
travismail's Avatar
you obviously have a short somewere. I would look inside the owners manual to see which items are on that circuit. If it is only the computer and/or fuel injectors then I would suspect a short in either of those. The injectors are fairly easy to test with a multi meter. I would start there.
stodd379
May 1, 2016 01:33 AM
clp29445
May 1, 2016 01:27 AM
dutch connection
Nov 10, 2009 02:14 PM
pikey
May 10, 2007 01:34 PM
