2000 S40 not starting
Old Jun 28, 2006 | 10:45 PM
clp29445's Avatar
Default 2000 S40 not starting
This is my first post...here goes. My 2000 S40 has gotten me through a lot of ups and downs, hopefully somebody out there knows what's the problem. This evening I went out to start the car. I turned the ignition; nothing happened. There is little to no power available inside the cabin for lights, etc. I figured I must have left a light running inside the vehicle. Anyways, I used a battery charger on the battery for approximately 15 minutes then tried to start the car again. This time, I hear a fast-paced, repeated clicking noise when the ignition is turned on, which abruptly stops when I release the key. Also, the lights inside the cabin are again working normally. Anyone know what is up?? Thanks for your help,
clp
Old Jun 29, 2006 | 12:08 AM
Default RE: 2000 S40 not starting
Might be a bad starter or still a weak battery.
Try charging the battery somemore.
The battery might be bad as well.
If there is a bad Cell then it might not start off the charger.
Old Feb 17, 2007 | 12:54 PM
airapetov's Avatar
I have the same problem now.
Hase your problem been fixed? Is it a starter problem?
Thanks
Old May 1, 2016 | 01:27 AM
kellyb's Avatar
This sounds like bad battery.
stodd379
May 1, 2016 01:33 AM
nkdmonkey
Nov 22, 2010 02:04 PM
dutch connection
Nov 10, 2009 02:14 PM
pikey
May 10, 2007 01:34 PM
