2002 S80 mirror motor replacement
here are instructions with pics :
Mirror Motor
-Before servicing the vehicle, refer to the Precautions Section.
-Remove or disconnect the following:
-Disconnect the negative battery cable.
-The mirror inside cover trim
-The door panel
-The electrical connector to mirror motor
-The nut attaching mirror assembly to door frame
-The outside rear view mirror
https://i.imgur.com/Ayllr.gif
https://i.imgur.com/FgeBS.gif
Remove the mirror glass:
-Fold the mirror glass forwards and inwards as illustrated.
-Grasp and pull the mirror glass lengthways until it releases.
-Work the glass out.
-Remove electric motor:
-Remove the 3 screws from behind the mirrored glass.
-Separate the connectors
NOTE
-Remember the positions of the connectors.
-Remove the mirror motor.
https://i.imgur.com/lU1Fp.gif
To install:
-Install or connect the following:
-The electric motor
-The electrical connections
-The 3 screws that go behind the mirror
-Install the terminal pins
-Fold out the mirror mounting on the motor
-Hook the mirror glass into the inner mounting
-Press the mirror glass into place.
-Place mirror in position in door
https://i.imgur.com/I2mpa.gif
-The connector
-The door panel
-The negative battery cable
Mirror Motor
-The door panel
NOTE
To install:
-The electric motor
-The connector
-The door panel
Stevens S80 2.9
Oct 22, 2013 06:06 AM
