my 2002 s80 t6 project, rebuilding motor
Old Nov 20, 2007 | 09:39 PM
my93vr4's Avatar
Default my 2002 s80 t6 project, rebuilding motor
rebuilding my motor heres pics, new piston rings , stem seal valves, water pump, idle pulley,tensioner pulley,14 head bolts, head gasket, timing belt, gaskets, and clean all motor inside from sludge cost me everything under $1,000 hope to be done with in 2 weeks its my project after work.
[IMG]local://upfiles/13513/6A22C75901AF4AB09AE861B5A56A4435.jpg[/IMG]
[IMG]local://upfiles/13513/4254AE3B97E94793908AD309D8BAAF7D.jpg[/IMG]
Old Nov 20, 2007 | 09:56 PM
Default RE: my 2002 s80 t6 project, rebuilding motor
Nice pics keep them coming.
Also make sure you check your turbo's really good.
Make sure they are good.
Old Nov 21, 2007 | 04:32 PM
my93vr4's Avatar
heres few more pics
Old Nov 24, 2007 | 03:14 PM
ramp's Avatar
Wow!!
[align=left] [/align]
Old Nov 24, 2007 | 09:54 PM
tripleb's Avatar
It sure looks like you have more than one engine torn apart!
Did you blow the head gasket?
Just curious why you would do a complete tear down.
Were the rings bad?
B
Old Nov 25, 2007 | 12:28 PM
my93vr4's Avatar
i did this because previos owner did not change oil on time and used cheap oil,engine have alot of sludgeinside and cooked oil that cloged small holes inside motor, valve stemseals went bad and 2 turbos ,,i'm changing piston ring because i'm already there ,nothink wrong with piston rings just wana changethem, car have 101,000 miles on it. in all turbo cars i recomend to use' fully synthetic oil' and change your oil on time,if you want your turbos to last , turbos for s80 are very expencive if you gona get them new... synthetic iol alot cheaper then turbos,or you will change your turbosalot sooner if you use regular oil, thats my thinking.feel free to add your coment
Old Nov 25, 2007 | 02:15 PM
tripleb's Avatar
I've seen good results with a good non-synthetic as long as the oil and filter are chenged every 3k. We used to see a bunch of lease return cars in this condition, even before out of warranty.
Good Luck with the engine.
B
Old Nov 28, 2007 | 09:08 PM
my93vr4's Avatar
heres 2 more pics
Old Nov 29, 2007 | 05:58 PM
Wow that was really sludged.
Almost the worse I have seen.
I have only seen one worse than that.
Old Jan 21, 2008 | 06:32 AM
sophisticars's Avatar
Is it all back together and running like a new one?
flatnb
Jan 9, 2011 09:29 PM
Sofar.
Jun 19, 2009 04:39 PM
jguerra3235
Mar 21, 2007 01:34 AM
maitresaman
Apr 8, 2006 03:30 PM
blase
Jul 21, 2005 09:44 PM
