2003 S80 t6 ooling fan problem
Old May 29, 2007 | 07:12 PM
fkudlack's Avatar
Default 2003 S80 t6 ooling fan problem
Hey everybody this is my first post. I own a 2003 dark blue S80 T6 with 29,000 miles on it. I have a problem with the cooling fan, it will run after the car is turned off untill the battery is completely drained. I investigated this after yesterday morning when my car was completely dead and figured this out. I wanted to know if anyone has had this problem and if there was any answers out there on why it is happening and any info on how to correct it. Everytime I turn off the car now i have to unhook the power to the fan so it won't drain the battery. Any help is greatly appreciated. Thanks - Frank
Old May 29, 2007 | 07:49 PM
Default RE: 2003 S80 t6 ooling fan problem
Check and see if your car is involved in the fan recall.
If not most likely the fan is bad.
Old May 29, 2007 | 09:09 PM
rockerfella174's Avatar
Simply Replace the fan...
Old Aug 3, 2007 | 01:18 PM
tiseminger's Avatar
I have replaced the fan. About $350 new. try to find a used one if you can.
Old Aug 3, 2007 | 03:03 PM
Johnny Mullet's Avatar
Open the hood and look at the electric box on the fan. If it has a black plastic cover, then get to the Dealer for the fan recall.
Old Aug 28, 2007 | 06:14 PM
costinstn's Avatar
i had the exact same problem with a 2002 s80 2,9 non turbo...it turned out to be the air flow meter...try that..maybe it will work
tettares
Sep 8, 2016 11:59 PM
dadlovsyall
Oct 2, 2015 10:56 AM
mike.velez
Oct 8, 2014 06:28 PM
bcolins
2001-2013 model year V70
Oct 24, 2013 09:13 AM
norasaint
Sep 20, 2012 12:53 AM
