2004 S-80 Both Headlightlights went out
Old Feb 20, 2012 | 09:13 PM
Roni's Avatar
Default 2004 S-80 Both Headlightlights went out
Was out of town and headlights were working fine, went into a restaurant and came out, started the S-80 and both headlights did not come on. Still are not working.
Any clues as to why?
Thanks..
Old Feb 20, 2012 | 09:44 PM
hickman123's Avatar
check the two head light bulbs good place to start.
Old Feb 21, 2012 | 07:43 AM
Roni's Avatar
The headlights on both sides would blow at the exact same time?
Old Feb 21, 2012 | 08:49 AM
mikecox1's Avatar
This is a total shot in the dark (pun intended), but is there a fuse dedicated to the headlights?
Old Feb 21, 2012 | 11:47 AM
hickman123's Avatar
the low and high are both powered by separate fuses but are grounded in the same place if the high beams work then you should have a good ground. the high and low beams are powed up through relays controlled buy the cem. you have to start some were i would start at the most basic and the thing that breaks the most the bulbs. your working on a car anything is possible. both bulbs blowing at the same time? sure why not.
Old Feb 21, 2012 | 11:53 AM
hickman123's Avatar
two separate fuses before the relays for high and low and then four fuses after the relay two for each side high and low. it looks like. i can email u the diagram if you feel like testing everything
RacerX
Jul 14, 2022 01:29 PM
dustin
Jul 14, 2009 09:06 PM
thetruthc32
Sep 27, 2007 01:36 AM
Pfeiffer124
Feb 23, 2006 02:11 PM
Alexander
Jun 28, 2005 10:33 PM
