2004 S80 T6 ABS Module Replacement?
Guys, My ABS module might have gone bad. I lost my cruise control and the ABS light is on. I seen where guys have sent theirs out to be rebuilt. I was wondering if there was a way I could find another one used and then take the car to a shop to re program the computer system. I have a body shop down the road that specializes in foreign cars, Audi, BMW and Volvo and Mercedes. I was told they have all the computer stuff to program all the cars....
Anyone have any ideas and or info on how I can obtain another one? I want to be sure I get one that matches my car make and such?
I can't get under the ABS module to see what model or serial it has? Any ideas? Possibly the VIN number????
Thanks for your help and assistance!
Spank.
Spank.
Remove the negative battery lead unplug the sensor under hood and attach or hold a multimeter to the sensor fins. Put the car in neutral with the E-brake on and you or someone press down on the brake pedal inward and out ward ,then stop half way use the 20ohms reading setting, record the numbers on paper, get back to me ...or just pull it apart like i did .!! Check out my picture album I have a step by step instruction on how to remove and fix the sensor with lots of how to info..you could also try and start with a used one for 50-75$ if that operation seems a little much..if i had a used or new one the repair would have been a 10 minute fix ....but i say DIY its easy in my opinion
P.S get back to me asap i just had a night mare with my ABS lights...check my (ABSlights,ignition switch,ball joint,cooling fan,electrical problems,all repairs) post
--------it cost me 5$ to remove the ABS LIGHTS problem hunker down the post "its a big one!"read up to the last post please buddy!
my pet monster is driving wonderful at the moment !
Last edited by Kiss4aFrog; 06-22-2013 at 01:43 PM. Reason: removed excessive "bold"
Did you need to get it programmed after replacing with a used BCM? Was it driveable after replacing the BCM? @spankey @doublebug
Um, yeah! I used Erie Volvo parts outfit out of NY called them told them my model, got one? Why wouldn't you match the car? Why take that risk?!!!!
you wouldn't request an S40 ABS module for an S80 would you?
