2009 S80 V8 Warning Message
Old Sep 21, 2014 | 08:10 PM
norse's Avatar
Default 2009 S80 V8 Warning Message
Hello,
I recently purchased a used 2009 S80 V8 with 65K miles on it. It is a nice car and I enjoy it very much.
Tonight, I was going for a ride and decided to open the car up a bit. I pressed down the gas pedal heavy when the car was shifting between gears (probably 2nd and 3rd). The engine revved up high, a check engine warning appeared, and then a shift up or reduce engine speed engine was displayed for less than a minute.
For the rest of the night the car ran perfectly fine. No further messages were displayed. Twice, I tried to repeat the circumstance by applying heavy throttle from stand still. Both times the engine ran smooth and no problems occurred. When I got home I checked the engine oil and everything looked great.
I am thinking it might of been a rev limiter kicking in? I have searched the internet and saw responses ranging from its nothing to check your plugs/ignition coils.
What do you all think?
Also, I do not plan drive like this all the time.
Thanks.
Old Sep 21, 2014 | 08:53 PM
damien360's Avatar
Normally the shift up message comes up because the engine is misfiring. You are going to need to get codes pulled for more assistance.
Old Sep 21, 2014 | 09:01 PM
norse's Avatar
Can I use a generic code reader I have (mac-tools) or do I need a volvo specific tool?
Thanks.
Old Sep 21, 2014 | 10:34 PM
norse's Avatar
Thanks.
I hook-up my mac code reader. No problems and no codes. I was also able to see no engine misfires and no cat problems.
I took it for one more test drive and was not able to replicate the problem.
Another forum is suggesting changing transmission fluid.
Old Sep 21, 2014 | 11:01 PM
damien360's Avatar
No it had nothing to do with the fluid. Once again when the check engine light comes on and the slow down or shift up message comes on it is because the engine has misfired. I personally don't like generic scan tools just because they aren't designed for one specific car like ViDA is. But if it isn't acting up and you can't get it to do it again just drive it the way it is. If it happens again I recommend going to the dealer to get the codes read and possibly diagnosed.
malaka
Aug 10, 2010 06:38 PM
raygnlz
Jul 12, 2009 11:36 PM
oscar23
Jun 27, 2008 09:52 AM
phoffman
Aug 31, 2007 11:42 AM
wyzard
Sep 11, 2006 12:05 PM
