99 S80 ETM Problem
Old Mar 25, 2010 | 11:14 AM
wildcard442's Avatar
Default 99 S80 ETM Problem
I have a 99 S80 2.9 with an ETM problem. Took it to a volvo specialist (not a Volvo dealer) and they said it needs a new ETM and that only a dealer can do that because it has to be "programmed".
Do only new ETMs have to be programmed or even used ones (if I swap one off my 99 X70 or find a used one somewhere)?
Old Mar 25, 2010 | 03:30 PM
anyone know?
Old Mar 26, 2010 | 09:22 AM
vegasjetskier's Avatar
Yes, the ETM has to be "married" to the car by the dealer and I doubt you will find a dealer who will do it with a used ETM. A better way to go, in my opinion, is a rebuild by http://xemodex.com/, which will use a non-contacting sensor in the ETM so that you don't have any problems in the future. Since they don't change the ETM itself, no programming is necessary. You just remove the ETM, send it in, they send it back, and you bolt it back on.
Old Mar 26, 2010 | 09:38 AM
Ya, I've been doing some research and I think that's the way I'm going to go.
Also, I am getting P0121, P0171, P0174, P0134 and P0154 DTC's on it. P0121 I think is the throttle position sensor... most likely because of the ETM right?. The rest are O2 sensor codes, do you think the ETM could be causing the O2 sensor codes?
Old Mar 26, 2010 | 09:45 AM
N_Vagrant's Avatar
the TPS codes should go off if the ETM gets fixed, but not 100% on the O2 sensors, they could be a misread or you could really have to change them. If you've noticed a decrease in performance and mileage since the O2 codes came on I'd look into it.
Old Mar 27, 2010 | 08:45 AM
I just pulled the ETM and it has a yellow sticker on it. Do the upgraded/replaced ones (with the yellow sticker) still have problems? My 99 S80 has 113,000 miles on it
Old Mar 27, 2010 | 09:44 AM
Oh and I don't think my ETS light is on, but it runs really badly. It will stumble, hesitate, etc. Where is the ETS light on a 99 S80 and what does it look like, and what does it mean if this light isn't on?
Old Mar 27, 2010 | 09:55 AM
Yes, they still wear out just like the originals.
Old Mar 28, 2010 | 10:32 AM
where is the ETS light and what does it look like?
Old Sep 29, 2010 | 05:06 PM
DSGBgaw's Avatar
Question
Hello my name is Allen, I'm new to the forum and new to Volvo's. I'm not tring to hyjack your thread but I have been looking for info for days and this is the closest thing I can find to my problems...
I have a 99' S80 T6 and it won't go over 20 mph, we put a scanner on it and it come back as the TPS, all I can find is the one from the dealership that is $700+ and then $160 for them to put it on.
So really my questions are....
Is the ETM and the TPS the same thing?
If not, by sending my ETM to http://xemodex.com/ will that fix my problem..
If it won't where is the cheapest place I can find one?
Thanks in advance,
Allen.
Old Sep 29, 2010 | 08:51 PM
DSGBgaw's Avatar
I really need some help guys, any info you have about it will help, this is my wife's car and she needs it for work!
Thanks again,
Allen
Old Oct 12, 2010 | 08:06 AM
generic1's Avatar
Default Any luck?
Sounds like ETS problems to me, bit I am a novice at these cars, still learning myself.. I am having ets issues, and my light will come on, but often my worse symptoms are without the light... Just wondering what u found out
Old Oct 12, 2010 | 10:56 PM
mustang's Avatar
if your car is idling real bad, try cleaning your ETM first? Real easy, this vid shows how.
http://www.youtube.com/watch?v=8Zaxtm-hdyo
s80luke
Jun 26, 2017 01:13 PM
cja1983
Engine & Internal
Jul 3, 2012 06:18 PM
cja1983
Jul 3, 2012 06:13 PM
cja1983
Jul 3, 2012 06:07 PM
Toxicity
Nov 21, 2007 04:00 PM
