ABS pump
while changing my ABS control module I found that the two wires that go to the electric motor on top of the valve body were exposed, the insulation had turned to goo and would fall off the wires by wiping them with my hand, after changing the module the car is still showing a code as having a bad control module. my question is could a bad motor on the top of the valve body cause this code?
