Access to the stc, trunk lock buttons.
Old Oct 19, 2009 | 10:00 AM
mercb's Avatar
Default Access to the stc, trunk lock buttons.
Can anyone tell me how you remove the panel to access the buttons for the STC and Trunk Lock?
My trunk lock switch is not working and needs to be replaced.
It is in the lock mode and will not shut off following the directions in the owners manual.
Old Oct 19, 2009 | 07:34 PM
andrei3333's Avatar
first i would disconnect the battery for some time, let things reset, then i would play with the remote and that buttong and try to get it to lock / unlock...your suggestion would be my last choice,
but if you want to get at that button, you gota remove the arm rest, cup holder, hand brake cover, center panel around the shifter and then you will see the screws for the a/c and stereo assembly where that button sits, its pretty easy actually
Old Oct 21, 2009 | 12:53 PM
mercb's Avatar
Thanks,
I was going to just bypass the switch, it's a feature I don't really need anyways, but I'll try the battery thing first.
Brian
sparker
Jun 11, 2012 10:55 PM
Mie518
Apr 30, 2011 02:49 PM
pacificnw2011
Sep 5, 2010 07:42 PM
finchy
Mar 23, 2009 07:46 PM
MoodsR4Cattle
Aug 13, 2008 10:49 AM
