Alignment
Old Aug 9, 2009 | 10:18 PM
bradw's Avatar
Default Alignment
In the past year I have had my 2005 S80 AWD aligned 3 times and it still pulls to the right. The dealership seems to think it is fine and perfectly aligned.
Am I missing something here?
Old Aug 9, 2009 | 11:32 PM
850tony's Avatar
how badly does it pull?
Old Aug 10, 2009 | 12:00 AM
matt14's Avatar
What are the camber measurements? If you have postive camber on the right and negative on the left, then the car will want to steer to the right. Even though it may be in "spec" this will still be a problem. If it continues, try swapping tires side to side to make sure you dont have a tire pull
Old Oct 19, 2010 | 05:29 PM
diehardgator1's Avatar
Mine pulls bad just had new control arms installed Pulled very little before but now if you take your hands off the wheel heads for the ditch
Old Oct 19, 2010 | 05:30 PM
can you adjust the cam on a volvo?
m1964
Mar 26, 2006 12:20 AM
ludeless
Dec 13, 2005 07:22 PM
MK1
Nov 30, 2005 10:45 PM
ludeless
Nov 23, 2005 08:14 PM
Osmenthe
Jul 9, 2005 01:36 PM
