Any ideas on how to fix this?
Old Nov 20, 2013 | 06:01 PM
kevin2's Avatar
Default Any ideas on how to fix this?
is glue the only option? if so what sort??
Old Nov 20, 2013 | 06:27 PM
Fogducker's Avatar
Pull it off and use 3M spray on adhesive......
Old Nov 20, 2013 | 10:09 PM
akabond's Avatar
how did it happen. i would use like a blunt ( not sharp) flat object and try to shove it back in..if that works.
Old Nov 21, 2013 | 07:59 AM
majorcode's Avatar
Kevin, This often happens with my car and I did try glue and many other stuff nothing is a permanent solution except you have to take that part out and get it refitted fabric from car interior professionals. Be careful with glue creates more mess then you think even if your are using transparent.
akabond, It happens with me most of the time due to heat, because in my area normally we often see 60+ C
Old Nov 21, 2013 | 09:16 AM
Heat, moisture, design, etc. It is like a bad head liner. Replace it or have it recovered.
drenman
Nov 29, 2016 07:35 AM
theotherpilot
Jul 10, 2009 12:28 AM
04arghh
Aug 23, 2007 02:44 PM
Volvorator
Mar 15, 2007 10:37 AM
