Blinker switch
Old May 31, 2010 | 06:56 PM
dpittard's Avatar
Default Blinker switch
I have a 2006 S80 and my blinker switch (the one in the car that you move to make the blinker lights flash) doesn't seem to fully engage. It doesn't start the blinker sometimes, and blinks really fast at other times, then starts regular pattern. I would think it's a bad switch in the steering column, but wanted to see if anyone has had this problem, and how they were able to fix it.
Thanks ,
David
Old Jun 1, 2010 | 11:14 AM
SVTfocusO3's Avatar
it needs a new stalk and you will need to tell them if it has the scroll for data or not.
Old Jun 23, 2010 | 11:13 AM
dpittard's Avatar
Default Who to install
Thanks for the reply. Is that something that someone with moderate ability with tools can do (removing screws and plugging in a few wires), or do I need to get it done at a dealership? It seems to be working now, but I know it will act up again.
BTW, it does have the data twist thingy.
Thanks again,
David
Old Jun 23, 2010 | 11:48 AM
SVTfocusO3's Avatar
You can do it, t-25 torx, long and skinny, and small phillips. Remove lower steering wheel cover, 3 torx, and then you will access the 2 phillips on the stalk. Make sure it is lined up when installing. 20 min.
It will be more with the data scroll.
Old Jun 23, 2010 | 03:16 PM
evoldarnoc's Avatar
May sound stupid, but before you go to all that trouble, have you checked to make sure its not a relay in the trunk causing the non-blinking/irregularity?
Old Jun 24, 2010 | 12:55 PM
dpittard's Avatar
Default Relay
Sorry to be so ignorant, but how do I check a relay? The car is only 4 years old, so I'm surprised that the switch would go, but I know sometimes these things are faulty.
If there is an easy way to check the relay, please let me know. I know that the first step is to start with the easiest possible problem.
Thanks,
David
littlemc90
Dec 23, 2008 12:46 PM
etype38
Jan 30, 2006 12:07 AM
s80mike
May 17, 2005 10:28 AM
nsmock
Apr 22, 2005 07:37 PM
Georgia Boy
Feb 19, 2004 02:24 PM
