Blow Off Valve
RE: Blow Off Valve
ORIGINAL: tech
Good luck 3/4 of the piping is plastic.
You would have to Tap into the piping off one of the turbo's.
I would have said have it welded to the Upper IC pipe, but if it is plastic you cannot.
My only other suggestion is to cut your stock Upper IC hose in half. Get a T-adapter for the BOV and be sure it is one that works with your BOV. Insert the T-adapter into both ends of the cut hose and clamp them down. Then attach the BOV to the other part of the adapter and run a vaccum line to it.
RE: Blow Off Valve
This is what it looks like.
Pic kind of small sorry it was a pic I found searching on AOL.
http://www.autozine.org/gallery/volvo/s80_t6_engine.jpg
One more
http://www.ipdusa.com/images/project..._engine_lg.jpg
One more
RE: Blow Off Valve
Also the rubber hose that is attached to it and the IC is where you should mount it if you need to use a T-adapter.
RE: Blow Off Valve
ORIGINAL: tech
They are all plastic except the rubber one from the intercooler.
Then go with the T-adapter idea then.
Cut the Upper IC rubber hose and put the T-adapter in clamp it on both sides and then put the BOV on top and hook a vaccum line to it.
Example of a T-adapter,
