Brake Failure/Service Urgent Message
Old Sep 20, 2007 | 08:01 AM
Sssnake's Avatar
Default Brake Failure/Service Urgent Message
I've noticed that sometimes when I brake hard (30mph+ to 0mph), I will get a quick "BRAKE FAILURE SERVICE URGENT" message for a second or two, but the car stops just fine. Any idea as to what might be causing this (before I take it to the dealer and get charged $800.00 for a brake job)? By the way my last brake job was about 9 months ago.
Old Sep 20, 2007 | 05:59 PM
Default RE: Brake Failure/Service Urgent Message
Is the fluid level close to the low level?
Old Sep 21, 2007 | 07:44 AM
Sssnake's Avatar
Now that you mention itI just had an oil change and tire rotation. I assumed that the dealer would have checked my fluid levels, but as they say you should never assume. I will take a look at my brake fluid level. Hopefully that's the problem.
Old May 26, 2022 | 08:32 PM
Hurlbut81's Avatar
If there is fluid and the light goes off what should you do?
Old May 27, 2022 | 06:55 AM
Dingus1's Avatar
Get the car scanned with a scanner than can communicate with all the modules in the car. Either a good scanner or a shop using Volvo's VIDA software. That way you can see what error codes are stored in the ABS module and others.
CASS60
Apr 3, 2019 08:29 AM
Sdaino
2001-2013 model year XC70
Aug 7, 2018 08:39 AM
sonajatt
Sep 25, 2011 10:40 PM
bluedevilbill
Jun 18, 2008 05:42 PM
dewdog1978
Dec 20, 2007 05:41 PM
