Brake Light
Old Feb 1, 2006 | 10:10 PM
JCVolvoS80's Avatar
Default Brake Light
I was wondering what could cause the brake failure message to come on ONLY when I brake into a turn...it's kind of annoying. Also, my SRS and airbag light came on after the body shop changed out my battery. When I hooked it up to an OBD II computer code reader, nothing comes up.
Old Feb 2, 2006 | 12:42 AM
Default RE: Brake Light
The Average scanner won't read SRS. The codes came from low Voltage. They will need to be cleared.
For the brakes check the brake fluid.
Old Feb 2, 2006 | 12:43 AM
JCVolvoS80's Avatar
Fluid looked clean. It was black but its not clumpy and has a transparent look to it. Any idea what else it could be?
Old Feb 2, 2006 | 01:15 AM
Was it at or close to MAX level?
Old Feb 4, 2006 | 01:34 AM
JCVolvoS80's Avatar
close to it, but not all the way.
Old Feb 5, 2006 | 05:30 AM
gordon368's Avatar
are your brake lights working(when you hit the brake pedal do they light up)? Do all of them light up? If one brake light goes out it causes the brake light failure to come on?
Old Feb 6, 2006 | 02:10 AM
JCVolvoS80's Avatar
Both brake lights work fine. See, the catch is it is only at high speeds or when I brake into a turn at ANY speed. This is what is truly confusing me. I'm going to have the low voltage codes cleared for the SRS/Airbag this week. I really really hope this isn't an expensive problem to fix because I'm still going to sell it.
Old Feb 11, 2006 | 03:41 PM
Make sure it is all the way on Max and see if it still does it. Or even go a hair over it.
Old Feb 12, 2006 | 01:41 AM
gordon368's Avatar
my onboard computer is telling me that i have a low battery voltage like when i leave the car off and have my sound system going, if i change my battery to a cold crank or a deep cycle battery, willl i get the same problem with the srs message if i change my battery?
Old Feb 12, 2006 | 02:06 PM
It might help some but not get rid of all of it. The Yellow top optima might be the best for the job.
With my little almost 400 watts I have to have my car running to power all 3 of the Amps.
nealeas
Mar 24, 2018 09:59 AM
glixons
Jan 4, 2015 06:15 PM
zinko
2001-2013 model year V70
Feb 11, 2014 07:18 AM
MaZoN
Aug 5, 2008 06:52 PM
mywifescar
Jan 13, 2006 12:59 PM
