bulb failure position light message
Kicked a code, but lights worked when checked. Remove code, good, but would kick a code on go.
Problem. Had to replace every bulb on the rear on both cars, was smarter on the second, thou.
Issue: Instead of cone shape contacts on bulbs, the the contacts were worn and dimpled inverted. Bulbs still worked. Cost about $33 for good quality bulbs and problem fixed. For good.
Wayne
Wayne
