BUSHING
Old Oct 5, 2008 | 03:03 PM
E99S80T6's Avatar
Default BUSHING
How do you replace the Upper Engine Torque Mount BUSHING?
Old Oct 5, 2008 | 06:01 PM
Default RE: BUSHING
Either you would replace the entire aluminum bracket with a new bushing in it or just by the urethane bushing from IPD and replace bushing only.
Old Oct 5, 2008 | 11:17 PM
E99S80T6's Avatar
Default RE: BUSHING
Inorder to replace do I just unscrew the bolt that goes through the bushing is that all?
Old Oct 5, 2008 | 11:34 PM
Default RE: BUSHING
Remove the bolt in the center. Then remove the 4 side bolts to remove the strut brace. Then take a hacksaw blade and cut the plastic from the old one and push it out. Then if you have the urethane one half goes on each side and install the rest and done.
satchmodog
Jul 29, 2006 12:08 AM
rmmagow
Apr 19, 2006 08:34 PM
Hon~Yaulker
Feb 22, 2006 04:30 AM
m1964
Dec 6, 2005 01:21 AM
cathym
May 17, 2005 08:11 PM
