Buying a higher milage S80 V8
Old Oct 12, 2017 | 10:17 AM
fuel's Avatar
Default Buying a higher milage S80 V8
Hi all,
I am looking to buy an '08 S80 V8 with higher milage. In addition to the standard mechanical items to look at, is there anything in particular I should pay close attention to when inspecting it? I know that the early V8's suffered a balance shaft bearing problem but I believe this was fixed on the '06 onwards models. How is the transmission - do they tend to last beyond 200,000 or maybe 300,000kms? Where do the engines typically leak from?
I've had a few Volvos over the years, but what gets my interest with this S80 is that it is based on the same platform as the Mondeo which I've also owned in the past.
Thanks!
Old Mar 17, 2018 | 08:28 PM
AndJello's Avatar
Well, it would be better if the struts have been replaced, also listen for a whining in the power steering, you may need to replace power steering reservoir as it is not serviceable, and has a filter in it, odd and not in the manual. My 2007 V8 AWD has 118000 was cared well. You might consider quickly dropping the skidplate to reveal the the oil filter area. Look for leaks, they will be very apparent on the other side of the skidplate. A simple hex and a hand driver will do to remove it, takes 5 minutes. I never tried removing it without ramps though.
Old Mar 18, 2018 | 12:55 PM
tony1963's Avatar
Valve cover gaskets leaking as well as an alternator are the two big jobs on these things.
Kyle Clifford Metzger
Dec 1, 2012 07:12 PM
S70driver
May 19, 2007 07:57 AM
OHVolvo
Oct 1, 2006 06:48 AM
gendy
Jul 17, 2006 02:22 PM
s40volvoH
Mar 18, 2005 06:43 PM
