A/C
Old May 5, 2006 | 01:48 PM
gordon368's Avatar
Default A/C
Hey,
I was using my Air Conditioner in the Parking lot..I turned it on to setting one, You can feel the A/C unit vibrate alot...It seems to be fine, then the next minute vibrate alot and make a noise, then the next minute vibrate....this goes on and off....Is this suppose to happen? Or is my a/c unit going bad? I havnt tried it while driving around yet ...
Old May 5, 2006 | 04:28 PM
dinopix's Avatar
Default RE: A/C
I noticed with mine that if I have the recirculate option activated, it vibrates. But, when I don't have that on, it doesn't seem to make any noise. I am pretty sure that it didn't always act that way, so I would be interested in finding out what the cause might be. Maybe just a flap not closing all that way due to age?
Old May 5, 2006 | 06:22 PM
gordon368's Avatar
Default RE: A/C
thanks ill give that a try today...
heh im not to familar with ac's...
Old May 5, 2006 | 09:14 PM
Default RE: A/C
Also if you have the Fan setting low with the A/C on you might feel the compressor cycling.
Old May 6, 2006 | 12:37 AM
gordon368's Avatar
Default RE: A/C
YES its on low when the vibrations happen, but is it supppose to happen that often?Like every 20 seconds?
Old May 6, 2006 | 09:46 AM
Default RE: A/C
The compressor cycles from Low pressure/Cold temp.
They are designed to do this to prevent the Evaperator from Freezing.
Turn the Fan speed up to about 1/2 and it will take longer to cycle.
