Changed Wheel Bearings now DTSC light is on
Old Feb 9, 2021 | 08:08 PM
du907's Avatar
Default Changed Wheel Bearings now DTSC light is on
I replaced struts and shocks and front wheel bearings on my 2008 S80. Got about a mile down the road and the DTSC light came on and the warning message says the DTSC is temporary turned off. I'm sure it's because I change the wheel bearings. The replacement bearings are *** and match perfectly. The wheel sensor is built into the back of the bearing. The pickups in the spindle were cleaned up while I had everything apart. OBDII shows no error codes but I didn't really expect it to read the ABS/DTSC codes.
Is there a re-set procedure because of changing the bearings? Is this a trip to the dealer to have it reset? I'm pretty sure the install is correct. Everything matched up as I checked all this when I reassembled it.
Ideas, experiences?
thanks
Old Feb 9, 2021 | 10:03 PM
ES6T's Avatar
There is no reset procedure. If the sensors are installed and connected, I'd bet it's the aftermarket bearings.
grimmeute
Mar 3, 2014 01:50 PM
98_V70_T5
Aug 13, 2010 06:49 AM
dsniner
Jul 7, 2010 10:54 AM
LucyDog
Suspension
Jul 24, 2008 04:19 PM
kk415
Nov 19, 2006 11:55 AM
