Check Engine Light
Old Nov 14, 2007 | 09:42 PM
Lee's Avatar
Lee
Default Check Engine Light
Afterhitting reallydeep pot holes or going over rough rail road tracks my check engine light comes on. Is there a way I can reset the light myself without haveingto pay my local mechanic to reset it? The car runsfine (knock on wood)with the light on. Could there be a short in the system somewhere? Once the code said an ox sensor was bad, another time the converter and a pump were bad. I had neither fixed. My Volvo is a 2001, S80, T6.
Thank you.
Old Nov 14, 2007 | 09:46 PM
tripleb's Avatar
Default RE: Check Engine Light
Pull the fuse for the ECM in the engine fuse box for 10 seconds or so.
Old Nov 15, 2007 | 12:30 PM
EuroDriverSD's Avatar
Sounds like you were in a pretty dirty environment. Check your air filter first, see if it got excessive dirt in there. I had to change mine immediately after the dust settled here in San Diego after the wildfires. After driving throught the ashes for a couple of days, I had some kind of warning come on. My filter was clogged with ash. After changing it, the message went away. If it's your check engine light, you can borrow an OBDII scanner from Autozone (free of charge, if you do it on their lot, or you can "rent" it, meaning you pay for it and take it home, and have all your money refunded when you return it - either way they won't charge you for using it) and turn off the light (or "MIL" as it is called in the scanner's language).
Old Dec 2, 2007 | 09:45 PM
Lee's Avatar
Lee
Pulling the fuse worked.
Thank you.
tngreg
Sep 5, 2022 07:27 PM
ErnstlS90
Oct 23, 2008 08:37 AM
mstrplmber
Aug 28, 2008 03:34 PM
BRB
Feb 9, 2008 12:29 AM
llama_of_doom
Aug 23, 2007 09:52 PM
