headlight adjstment & bulb position
Old Dec 2, 2007 | 10:11 PM
veso_ht's Avatar
Default headlight adjstment & bulb position
how do I adjust the headlights, the book says take it to the dealer.... is that really the only way? also, my headlight was out and i had a bulb position failure light, now i have a new bulb in and all lights work great but the message still comes on? wats' up?
thanks
99 s80 t6
Old Dec 2, 2007 | 11:15 PM
01_fast_ride's Avatar
Default RE: headlight adjstment & bulb position
You can adjust it yourself. What you are looking for are the adjustment screws on the back and sides. On the S60s they are white, not sure if they are the same on the S80s. The bulb position failure is usually reserved for the taillights. I would check to see if a bulb is out or just loose; they can act funny at times.
Old Dec 3, 2007 | 08:49 AM
master_pre's Avatar
ORIGINAL: 01_fast_ride
Yep, check your taillights. I ended up replacing all the bulbs while I was at it!
dcb07
Mar 11, 2010 01:41 AM
gordon368
May 19, 2007 03:44 AM
master_pre
Oct 22, 2006 12:29 PM
S60T5
Mar 24, 2006 02:32 PM
dreamcars80
Mar 28, 2005 03:04 PM
