Check engine light
Old Mar 17, 2013 | 06:39 AM
Piayah's Avatar
Default Check engine light
Hi i just bought a 2000 volvo s80 t6 se last week and loving it. The car drives so quite and so smooth driving it for a week. But today suddenly a check engine light come on and stays on but it drives the same, still so smooth and quite. Could it be possible hat this,is just some faulty warning?
Old Mar 17, 2013 | 08:09 AM
akabond's Avatar
well what are you waiting for go to a auto shop and get it scanned for a code for free..just as simple.
You dont want to wait or ignore
Old Mar 17, 2013 | 09:14 AM
kirketh's Avatar
Default cel
sometimes these cars dealerships clear the codes without fixing problems, and they reappear after a hundred miles...
Old Mar 17, 2013 | 04:14 PM
Piayah's Avatar
Thanks guys
Old Mar 21, 2013 | 10:09 PM
Piayah's Avatar
Went to a volvo mechanic, they said its just a sensor in the exhaust pipe- to fix $1000!!!!!! There are 4 sensors in exhaust and only one is not working. I bought my own obdII tool now.
Old Mar 21, 2013 | 10:36 PM
akabond's Avatar
WOW that is $$$$. what was the code number that was pull up
Old Mar 22, 2013 | 03:22 AM
Piayah's Avatar
The mechanic didnt give me the code. I havent use my obd2 yet. The mechanic may have deleted the code.
Old Mar 22, 2013 | 03:34 AM
Piayah's Avatar
I will check later akabond if some code will come up from my obd2
Old Mar 22, 2013 | 04:11 AM
More than likely it's a bad o2 sensor. Depending on the fault, it could take several hundred miles to reappear. You can scan the system and see if the code is in there.
Old Mar 22, 2013 | 08:05 AM
akabond's Avatar
like this?
Old Mar 22, 2013 | 10:54 AM
I was referring to using an OBD-II code reading scanner.
Old Mar 23, 2013 | 12:41 PM
majorcode's Avatar
Akabond, how did you get these messages on the panel?
Old Mar 23, 2013 | 01:37 PM
akabond's Avatar
if you read the footnotes that should show how to do it.
Old Mar 26, 2013 | 05:30 PM
Piayah's Avatar
The mchanic has deleted the code, it doesnt show in my obdii anymore, but i still have an x on CAT and O2S when i do a ready test. The mechanic theres no urgent things i need to fix in my car as it is driving great.
Old Mar 31, 2013 | 03:14 AM
Piayah's Avatar
Check engine light has come back on again. Used my obd2 scanner tool and it gave me P1132 o2 sensor heating circ.. Bank 1+2-sensor1short to B+. ... I have no idea what this means. Can someone help me, is this a minor thing or i must get this fixed?..... For now, i just erase the code so my check engine light will go.
tngreg
Sep 5, 2022 07:27 PM
ErnstlS90
Oct 23, 2008 08:37 AM
mstrplmber
Aug 28, 2008 03:34 PM
BRB
Feb 9, 2008 12:29 AM
llama_of_doom
Aug 23, 2007 09:52 PM
