Check engine light?
Old Jan 19, 2014 | 04:42 PM
tianamccrae's Avatar
Question Check engine light?
I have a 2000 Volvo s80 T6 with 184,000 miles on it!
The check engine light comes on and the code reads EVAP leak.
We've replaced all the hoses, the converters, and the gas cap...what else can it be? O2 sensors??
Also my car leaks so much oil I need to refill It every week and a half. it leaks out of the top portion.
Any ideas?
Old Jan 19, 2014 | 04:45 PM
Hi and welcome to the forum.
What is the code?
Old Jan 20, 2014 | 10:30 AM
ES6T's Avatar
PCV and evap system are totally different.
Old Jan 20, 2014 | 10:55 AM
What is the code? Could have a bad valve or vent at the fuel tank.
Old Jan 20, 2014 | 11:44 AM
the code is P0455
Old Jan 20, 2014 | 11:48 AM
kwatt's Avatar
Did you look at the canister hoses? Should be a big J hose
Old Jan 20, 2014 | 12:38 PM
yes and it seems fine
Old Jan 20, 2014 | 07:01 PM
it shakes when it goes to start and says "engine system service required immediately" then I turn it off and turned it back on and now it says SRS airbag service urgent.
the key is also very hard to turn now.
Any ideas?
tngreg
Sep 5, 2022 07:27 PM
ErnstlS90
Oct 23, 2008 08:37 AM
mstrplmber
Aug 28, 2008 03:34 PM
BRB
Feb 9, 2008 12:29 AM
llama_of_doom
Aug 23, 2007 09:52 PM
