Cleaning a throttle body
Old Jul 31, 2012 | 10:49 PM
donf's Avatar
Default Cleaning a throttle body
OK, I just cleaned out the throttle body/MAF on my Tahoe and the improvement was so dramatic I thought I'd use the rest of the cans of cleaners on the '05 S80.
Alas, I can not seem to find the throttle body - at least it is not where the one pictured in the tutorial over at Matthews is. Am I going to have to remove the intake manifold and whatever is over that just to get to it? Seems like there must be an easier way.
Old Aug 1, 2012 | 08:44 AM
akabond's Avatar
ya actually i have been wanted to clean that too on my 2006 2.5T too.
This is what i found :
-Remove the intake manifold between the front cover plate and the air cleaner (ACL) housing.
Disconnect the battery negative lead.
-Disconnect the hose between the charge air cooler (CAC) and the throttle body (TB) at the end of the throttle body (TB). Move to one side.
Remove the tie strap at the connector.
-Disconnect the throttle body (TB) connector.
Remove the throttle body (TB).
Clean the mating surfaces thoroughly.
Install
-a new throttle body (TB) with a new gasket . Tighten to 10 Nm
-Connect the throttle body (TB) connector
the tie strap at the connector the pipe between the throttle body (TB) and the charge air cooler (CAC)
the battery negative lead. Battery, disconnecting
Now i dont think you have to remove the body i.e. i guess you can clean while the body is bolted because if you then install it "After replacing the throttle unit, the throttle unit must be adapted using the vehicle communication input: Adaptation of the electronic throttle unit. Remedy as necessary". hmm
Attached Thumbnails Cleaning a throttle body-volvo1.jpg   Cleaning a throttle body-volvo2.jpg   Cleaning a throttle body-thro.jpg
treestone27
Apr 29, 2014 07:40 AM
go2sharks
Jan 21, 2009 10:24 PM
mturner333
Oct 18, 2005 09:21 PM
DanR
Sep 7, 2005 02:31 AM
proudmonkey
Jul 21, 2005 10:01 PM
