climate control does not work
Old Apr 27, 2009 | 12:42 PM
pdougan916's Avatar
Angry climate control does not work
i took my 2000 s80 to have the timing belt replaced. the mechanic replaced the belt, timing gears, water pump, camshaft seals. i went to pick up the car. but now the climate controls do not work. nothing works below the radio. so it is still there. could they have blown the CCM or is there a reset. i just paid the guy $1200.00 and cant drive the car plz help before i go crazzyyyy
Old Apr 27, 2009 | 07:35 PM
The module might have died. Try to disconnect the battery and connect the positive and negative terminals together for 5 minutes and then connect again and see if it works.
Old May 3, 2009 | 06:32 PM
ARvolvo's Avatar
I have this exact same problem. I am an idiot when it comes to cars. How do you connect the negative and positive terminals?
Old May 3, 2009 | 09:11 PM
kevmcrae's Avatar
Under the trunk floor panel is the battery. Remove the hold downs that hold the battery tight. Disconnect the battery wires from the terminals, then hold the two wires together. Then hook them back up where they were. ALWAYS be carefull to put red back on the + terminal and black on the - terminal.
Old May 4, 2009 | 03:55 PM
abflip567's Avatar
yeah, you are just short circuting your system and it basically resets your car
Old May 4, 2009 | 07:03 PM
You are draining the capasitors in the entire car when you hold the cables together.
Old May 18, 2009 | 05:48 PM
pdougan916's Avatar
Default update
mechanic says it needs to be reprogrammed so he has sent it off to be fixed that was 3 weeks ago now when i call i get . it has not returned from the shop yet ARGHHHHHHHH
Volex23
Jun 1, 2014 05:03 PM
whistman
Sep 25, 2013 04:34 PM
rspi
Jul 31, 2012 07:38 AM
zx2max
Oct 9, 2006 03:42 PM
jfikentscher
May 31, 2006 09:58 PM
