coolant level
Old Aug 10, 2011 | 11:09 PM
aprotec58's Avatar
Default coolant level
I have a 2000 s80 volvo with low coolant. When i add it to the overflow tank,, it doesn't want to draw down into the radiator. Also, the top radiator hose collapses some. If i drain the system, how will i refill properly?
Old Aug 11, 2011 | 05:34 AM
If the expansion tank is full, why do you think you have low coolant?
Old Aug 11, 2011 | 08:08 PM
Carrots's Avatar
The expansion tank on these cars is pressurized- they don't have a conventional radiator cap/ overflow tank setup- the expansion tank is directly connected to the entire cooling system, so filling it directly fills the whole system through the bottom hose on the tank. The top hose is an air bleed.All you do is fill the tank until the level stops dropping down. Then, run the car until it reaches normal operating temperature, shut it off, allow it to cool for several hours, then top off the tank.
As for the hose collapsing, sounds like your thermostat might be stuck. Change it
Old Aug 26, 2011 | 08:10 AM
aprotec58's Avatar
Yes, I did change the thermostat, drained the entire system (drained block from the back side of the engine, closest to the firewall) then refilled, and still the car only drinks between 1 to 1 1/2 gal of coolant. the specks call for 2 1/2 gal. light still on the dash indicating that the coolant level is low. Also i have no ac/heat function. any ideas?
Old Aug 26, 2011 | 08:46 AM
Have you checked the wires going to the expansion tank?
Old Aug 28, 2011 | 10:33 PM
aprotec58's Avatar
yes, wires are plugged in and secured
Old Aug 29, 2011 | 07:23 AM
If the expansion tank is full you likely have a bad sensor, float, or some other wiring problem.
Is the car overheating?
Spoonman
Jun 14, 2017 02:24 PM
volvo4lifeson
Sep 28, 2012 07:54 AM
kirkgrau
Nov 7, 2010 03:29 PM
tinneric
Oct 3, 2008 07:22 PM
simon_mahoney
Jul 30, 2006 11:56 AM
