Coolant Level Problem.
Old Feb 10, 2012 | 01:47 PM
Anna Hall's Avatar
Question Coolant Level Problem.
For weeks I've been getting the message "Coolant level low. Stop Engine ASAP". I check the coolant reservoir and it is almost completely empty. I have been adding coolant (or just water) and the message will go away, but after a few hours of driving the message reappeared and I had to add more coolant. I thought it was a radiator leak, so I had the radiator replaced on Thursday ($500!). Today, Friday, I got the same message again after about two hours of driving. The reservoir was empty again. If the radiator is not leaking, then what could it be?
Old Feb 10, 2012 | 05:47 PM
gabyman97596's Avatar
Check the hoses for the radiator and the back hoses for the heater core also, it might be that the water pump might be leaking also. Did the car over heat? Cause if it did your coolant might be going to the engine and you have a broken headgasket.
Old Feb 11, 2012 | 05:28 PM
Lunger's Avatar
try replacing the cap on the coolant resevoir. That is if you don't have a issue with how the motor is running (i.e. head gasket). check the carpet to see if the heater core isn't leaking. Smell the exhaust to see if it smells sweet like coolant burning. If no issues with engine performance and no leaks are detected then try the cap.
Old Feb 26, 2012 | 08:09 PM
light8008's Avatar
yeah, you should check the hoses for the radiator and the back hoses for the heater core first~~~
Old Feb 27, 2012 | 05:02 PM
hickman123's Avatar
pressure up the system with the pressurizer tool and see what is leaking don't shoot from the hips and assume something is leaking. as for what it is the list is too long for maybes. it can be anything that has coolant in it.
Old Feb 28, 2012 | 07:42 AM
bcpape's Avatar
There are only 2 things that will cause loss of coolant. One is a leak. Does not matter where. If you see coolant under the car or in your interior, you have a leak. The other is that you are burning coolant due to a head gasket failure. If you can't visually see coolant leaking from anywhere, chances are you have a head gasket issue. Consuming that much coolant, you should easily see where it's coming from.
Old Mar 9, 2012 | 10:16 AM
padams's Avatar
Default Heater Core Leak - S80
I've found moisture on my driver's floor mat. Obvious heater core leak ? Is there a step by step replacement resource you recommend ? I hate take time to drive to the library to read the tech manual. Can you provide it or perhaps available online ?
Old Mar 9, 2012 | 04:54 PM
spacedogb's Avatar
padams Im sure you found your leak but if you havent, check the coolant bottle itself. Mine had a pinhole leak that would only happen while pressurized and would drain the bottle in hours.
Old Mar 10, 2012 | 10:05 AM
bcpape's Avatar
If you want to attempt the repair yourself, I might suggest that you buy the software for the Volvo repair application, otherwise known as an electronic manual. The Volvo version is called Vadis and you can buy it all over eBay. I bought mine for under $10 including shipping. It contains an ocean of information including step by step repair procedures. What's more, is if you want to take the next step and by an interface tool for your laptop, you can then plug in to your car for diagnostics and clearing of error codes. That is more expensive. You can get that tool from Alibaba out of China for around $200-$300. That will then interface with your VADIS program.
The heater core is not an expensive part. The repair is an interesting journey...
Spoonman
Jun 14, 2017 02:24 PM
volvo4lifeson
Sep 28, 2012 07:54 AM
kirkgrau
Nov 7, 2010 03:29 PM
tinneric
Oct 3, 2008 07:22 PM
simon_mahoney
Jul 30, 2006 11:56 AM
