coolant mysteriously vanishing where do I look
Old Feb 15, 2012 | 01:01 PM
blue02's Avatar
Default coolant mysteriously vanishing where do I look
First- don't see it on the driveway...
2002 s80T6 97K... love it
Couple of months ago began to notice coolant was at min, added to max, and have been doing this ever 3 or 4 weeks (only putting about 600 miles a month on the car). Don't see white smoke when running (some for a few seconds at start) and the oil and trans fluid look clear and don't smell like coolant. I don't see any obvious leaks in the hoses (haven't looked too hard, don't know if there are any spots where this is likely to occur. Read some previous posts and thought it might be the cap (which was slightly cracked, replaced it, didn't seem to help) so I thought I'd throw it out there and see if anyone had any ideas. Don't know if this is an easy thing for a mechanic to pinpoint but haven't gone that route yet.
Old Feb 15, 2012 | 03:42 PM
mikecox1's Avatar
Based on what you have posted, I would be looking toward the water pump as my prime suspect. I am changing mine out this weekend
Old Feb 16, 2012 | 09:33 AM
blue02's Avatar
thanks. where is the water pump located on that model?
Old Feb 16, 2012 | 11:00 AM
mikecox1's Avatar
It is on the passenger's side of the motor, the timing belt is what turns it.
Old Feb 16, 2012 | 03:43 PM
blue02's Avatar
thanks Mike, have a good time (hope its quick) replacing yours this weekend
Old Mar 1, 2012 | 01:45 PM
padams's Avatar
Default Coolant loss...
You might check the bottom of the coolant resoviour - the fitting where the
fluid level sending indicator enters the reseviour may have failed.
Old Mar 1, 2012 | 01:50 PM
padams's Avatar
On a related issue, my 2000 S80 has a foamy oil in the reseviour - not on the engine oil dipstick nor the transmission dipstick....
Old Mar 13, 2012 | 12:59 PM
m3excempt's Avatar
Check your inlet hose that goes to your heater core by the fire wall,coolant leak crawl on that insulation.i just change mine this weekend.
jethrobodean
Feb 16, 2013 07:50 PM
cmayo313
Mar 18, 2011 12:09 PM
dean2365
Mar 9, 2011 03:05 AM
Ahmed
Aug 30, 2009 01:58 PM
timk
Nov 16, 2007 08:33 PM
