Cruise Control quits
Old Nov 16, 2011 | 12:59 PM
Falasi4's Avatar
Default Cruise Control quits
Any thoughts on what would make cruise control quit while just cruising down the highway? Problem has gotten worse over the last couple of months to the point where sometimes I can't even set the cruise to start with. No apparent pattern to this and within any random amount of time it may/may not work again.
2000 s80 2.9 (non-turbo)
Old Dec 3, 2011 | 11:21 PM
mustang's Avatar
Does your check engine light come on? does you ABS light come on? Does your message area say "brake failure stop ASAP?
if so i'l guess it's your ABS module--same thing happened to me. I had the ABS fixed and all was well.
Old Dec 4, 2011 | 07:03 PM
Falasi4's Avatar
I had all the typical abs symptoms last fall and replaced the abs module - all was apparently fixed and no codes or anything showing up now.
Old Dec 11, 2011 | 08:15 AM
jbuck's Avatar
You most likley have a vacuum leak in the line somewhere. Find the control unit and replace all the vacuum tubing. As the hole go bigger the problem got worse.
vfrhon
Aug 21, 2016 12:14 AM
Falasi4
Sep 15, 2011 02:43 PM
rspi
Mar 7, 2010 06:13 PM
jfikentscher
May 31, 2006 09:58 PM
dbehr
Sep 30, 2004 09:46 AM
