Diagnostic Codes For a S80 T6
Old Jan 8, 2009 | 06:10 PM
Hamzel's Avatar
Default Diagnostic Codes For a S80 T6
I got these codes and i cant quite understand them.The codes are Troubleshooting P1332, and Troubleshooting P0013. The codes are causing the diagnostics to mark check engine.
Old Jan 8, 2009 | 06:57 PM
Default RE: Diagnostic Codes For a S80 T6
It means either it is slightly out of time or the VVT solenoid is bad. Or something along those lines.
Old Jan 9, 2009 | 08:40 PM
Hamzel's Avatar
Is it an easy fix or is it gonna cost me an arm and a leg?
Old Jan 9, 2009 | 09:17 PM
Did someone just to the timing belt?
If the solenoid is bad you might be able to replace it your self. There is only 4 screws holding the solenoid on.
Old Jan 9, 2009 | 09:45 PM
Hamzel's Avatar
great where would i find the solenoid is it near the timing belt
Old Jan 9, 2009 | 10:10 PM
Yes it is once you remove the black spark plug cover by the timing belt there is a round thing attached to a square looking thing. That is it it bolts to the cam cover just over one of the cam shafts.
Old Jan 10, 2009 | 11:34 AM
Hamzel's Avatar
Is it called the solenoid switch?
Old Jan 10, 2009 | 03:09 PM
Some call it a VVT solenoid valve or camshaft reset valve.
Old Jan 11, 2009 | 03:56 PM
Hamzel's Avatar
I took the car apart and found the solenoid but it doesnt look damage. How would i know if it needs to be changed
Old Jan 11, 2009 | 07:20 PM
To really know if it would need to be replaced you would have to have the proper software to see if working or not.
But usually that is the problem but not all the time it is about a 60/40 it is bad.
axelm
Jul 3, 2015 08:48 PM
po berglund
Jan 22, 2010 01:24 PM
pittpan2005
Mar 16, 2008 10:23 AM
troy65
Dec 19, 2007 01:00 PM
rene
May 18, 2007 07:17 PM
