ECM-2320 Injector cyl 2 - signal missing
Old Dec 22, 2023 | 03:11 PM
sirdani's Avatar
Question ECM-2320 Injector cyl 2 - signal missing
Hello,
It is a Volvo S80 2002 2.9i 2922ccm B6294S2 engine code.
6 cylinders
Vida code:
We inspected with repairman, try to spray the connectors with contact spray. But still the same. Repairman told maybe injector is worn. Injector 2 start sometimes when engine reach working temperature. Other injectors working fine, so i have 5 cylinder now. Replacement part only arrives after Christmas holiday.
I need to drive the car at Christmas. 1 hour drive to address, stay there, then some hours later 1 hour drive back.
Now the car turns off cylinder 2, but other 5 works. Can I use it for that 1+1 hour drive?
Old Dec 23, 2023 | 01:21 PM
did the tech swap the injector with one next to it to see if the fault moves with the device? Personally I would not drive a long trip with a wonky injector that may cause a lean condition that can risk burning a valve unless you decide to unplug both the injector and the coil pack - but as noted that's just my personal opinion. With the injector off (assuming its not leaking) and no spark, you'd just be pushing air through that cyl.
taggarc
Sep 1, 2025 11:43 AM
Durie1
Volvo C30
Sep 3, 2022 08:54 PM
Mitchell13
Jan 5, 2020 10:11 PM
Hobo
Mar 9, 2017 05:28 PM
drizzledazzle
Oct 11, 2007 02:39 PM
