Electrical
Old Oct 10, 2006 | 02:59 PM
SquareDanceSteve's Avatar
Default Electrical
the left control arm on my stearing column (blinkers, highbeams and read) is compleatly dead. Any ideas?
Old Oct 10, 2006 | 05:43 PM
master_pre's Avatar
Default RE: Electrical
It's either the Control Module of the software, or both. "Tech" knows exactly what the broken part is refered to as. If you take it to the dealership, they will easily identify the issue.
Old Oct 10, 2006 | 10:41 PM
Most likely the steering wheel module.
Old Oct 11, 2006 | 01:33 AM
how much are we talking?
can i do it myself?
Old Oct 11, 2006 | 01:38 AM
Dealer has to do it. They have to download software to make it work.
I think like $300.0 or so but not 100% sure.
Old Oct 11, 2006 | 09:58 PM
update*
Catastrophic Failure while driving
guages started failing one by one, warning lights started coming on one by one, then all the warning lights went out then dash illumination went out. geartronic failed so I couldnt shift out of 4th gear (automatic also appears to have failed)
the car is currently underway on a 70 mile journy on a flatbed with all the windows down (they wouldnt go up). But yes powerbreaks and cabin illumination and door locks function well.
Old Oct 11, 2006 | 11:06 PM
master_pre's Avatar
That's a lot of failing. When the electrical goes bad, it can be to a large degree, but you already knew that!
Please update us on what ended up being the issues.
Old Oct 25, 2006 | 03:17 PM
Alternator, Battery and Time, $920 and now my service light comes on when I start the car but turns off a couple minutes into my drive.
Apparently Volvo has a funky take on "limp mode" Instead of telling me it just shuts systems down.
Old Oct 25, 2006 | 03:47 PM
master_pre's Avatar
Ouch!!! Do you know what's causing service light to turn on?
Old Oct 26, 2006 | 02:07 AM
none
Old Oct 26, 2006 | 11:16 AM
master_pre's Avatar
Have you had the code pulled to find out what might be tripping it up?
Old Oct 26, 2006 | 01:18 PM
I need to buy a code reader, I live in a very rural place service is few and far between and volvo service is impossible
malcolm
Sep 9, 2009 09:45 AM
jdbs3
Nov 16, 2004 11:42 PM
billm261
Aug 11, 2004 11:27 AM
Sweet740GLE
Jan 8, 2004 02:13 AM
GaryW
Oct 21, 2003 05:26 AM
