Electrical Problem - Bulb Indicator Light
Old Nov 16, 2004 | 02:56 PM
jdbs3's Avatar
Default Electrical Problem - Bulb Indicator Light
I have an electrical problem involving the bulb indicator light on the dash board.
Symptoms:
- Turn on headlights and bulb indicator light goes on.
- Turn on high beams and it *sometimes* it goes off.
- Turn on the right turning signal and the bulb indicator light will flash on and off alternating with the right turn signal.
- Turn on the left turning signal and it has no effect on the bulb indicator light.
- When the lights are on, the bulb indicator light is on 95% of the time. If it is off and I hit the brakes, it goes on. Take my foot off the brakes and it goes off.
- If the lights are on and the bulb is off, I also found it would react to just altering my speed, i.e. letting up on the gas or giving the car more gas would turn it on. Take my foot off the gas or go back to a steady gas flow and it would go back off.
I checked all the lights; they all work. So it certainly seems like an electrical problem.
Does anyone have any ideas on how a lay person might be able to diagnose/fix it, or is this something best left to a mechanic?
Is the problem something simple or an indication of a more major problem?
Thanks!
Old Nov 16, 2004 | 03:10 PM
jdbs3's Avatar
Default RE: Electrical Problem - Bulb Indicator Light
Te car is a 1990 Volvo 240 DL sedan
Old Nov 16, 2004 | 11:42 PM
First i would try checking the connections on the taillight assy.They get dirty and act up sometimes.Make sure they are clean and tight.Second the light works based on resistance if you have 2 diffrent brands of bulbs that can make the light stay on as well.Check those things out and let me know.
zloetakoe
Sep 16, 2024 07:37 PM
j_allworth
Nov 26, 2014 08:46 PM
dogon
Jul 2, 2008 09:52 AM
rjfoster03
Jun 30, 2007 04:54 PM
s70familoy
Feb 21, 2006 01:43 AM
