Emission System Service Required
Old Dec 10, 2008 | 10:40 PM
PieceKeeper's Avatar
Default Emission System Service Required
Car: '01 S80, 2.9L, 113000 miles
Received the above message and the Check Engine light is illumated -alternates between flashing and staying on solid.
There is a strange, somewhat 'rotten' smell in engine compartment and at the tail pipe.
Engine runs rough almostas ifa cylinder wasn't firing.
Recent maintenance activity:
Changed spark plugs about 250 miles ago.
Coincidence or not: this failure occurred while i was test driving a set of snow chains. The chains induced some serious vibration to the car. The warning message appeared after driving a short distance with the chains.
Question: I'd like to know if you all think this is related to a coil going bad or maybe a MAF, and what arethe recommendations on how to get this fixed. A search of the forums returns a few other posts that seem similar to my situation.
________
Alaska medical marijuana
Old Dec 10, 2008 | 10:53 PM
andrei3333's Avatar
Default RE: Emission System Service Required
be certain and have someone scan the car
i had that message but not the symptoms and it was an oxygen sensor
Old Dec 10, 2008 | 10:59 PM
Crito's Avatar
Banned
Oxygen sensor would be my guess from the "rotten egg" comment.
And why is it people always assume the last thing they did had something to do with it? It's the fallacy of false causation. Just because the sun comes up every morning after the roosters crow does not prove roosters make the sun rise.
Old Dec 11, 2008 | 07:49 AM
Also make sure it isn't misfiring. Flashing check engine light is usually misfiring. But it can also flash from the O2 sensor.
Old Dec 11, 2008 | 07:59 AM
With the S80, what are some of the more common causes for misfire? Is the car particularly sensitive toa type of spark plugs??
________
Chevrolet Monza
Old Dec 11, 2008 | 08:11 AM
Plugs and coils are very common failures. The coils more than the plugs though. The OEM T6 plugs are Bosch Platinums.
Old Dec 11, 2008 | 08:13 AM
The non-turbo cars I would go with the OEM plugs.
Old Dec 11, 2008 | 08:49 AM
air force rascal's Avatar
A rotten egg smell..tells me it could be a CAT starting to Clog up..do you have difficulty in climbing hills..like you don't have enough power or get a stronger smell..?
Old Dec 11, 2008 | 08:50 AM
Could be an EGR Valve also.....just a thought...Good Luck !!!
Old Dec 11, 2008 | 09:04 AM
I've been cautious in my driving since this started happening, can only notice the rough engine idle & smell, it does seems to not have as much power when pulling away from a stop.
If the engine was misfiring on a cylinder, i think it would explain the loss (reduction)of power / rough idle; the unburned fuel being dumped in the exhaust and the rich fuel/exhaust mixture passing through the CAT might explain the 'rotten' smell and the subsequent triggering of the emissions warning. Thoughts??
I'm getting the codes pulled this morning, will post them later.
________
Colorado dispensaries
Old Dec 11, 2008 | 09:33 AM
Could very well be correct. Yes the codes will help alot more from here.
Old Dec 11, 2008 | 11:38 AM
Pulled the codes
P0103B:
3503 - misfiring
3513 - misfire cylinder #1
I'm having the cheap plugs pulled and replaced with the Bosch Fusion. We'll evaluate, and if need be then replace the #1 coil module. Fortunately no flags were set for bad O2 or MAF sensors.
________
AVANDIA CLASS ACTION LAWSUITS
Old Dec 11, 2008 | 12:15 PM
Good I hope the plugs get it running in top shape again.
Old Dec 11, 2008 | 03:01 PM
Plugs turned out to be okay, the #1 coil was bad. Replaced mid grade plugs with Bosch Platinum Ir Fusions, new #1 coil module, labor = $280.00 Runs like a champ again. FWIW, the mid grade plugs worked butthe engine seemed a bit less peppy though. Here's a case where I think it pays to get the better performing plugs.I'll be watching fuel economy results next week when Imake a Christmas cross-countrydrive.
________
Gong Bongs
Old Dec 11, 2008 | 06:00 PM
Glad it is all fixed now.
Old Dec 12, 2008 | 07:25 AM
BILL_MCCASSEY's Avatar
Make sure to have the codes pulled with a volvo scan tool. Most others will not show all of the codes.
Old Dec 12, 2008 | 09:36 AM
  #17
Crito's Avatar
Banned
ORIGINAL: air force rascal
Come to think of it, when I had that rotten egg smell (in a different car) I had to change the O2 sensor and poke a hole with a long screwdriver, er, I mean, and replace the ridiculously expensive catalytic converter too. []
robingichuhi
Feb 22, 2017 04:34 PM
S80guy
Aug 18, 2014 07:18 PM
chrissygm
Sep 30, 2008 05:53 PM
volvo888
Jun 6, 2006 09:12 PM
OverTheTop
May 6, 2006 09:50 AM
